Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the motherboard.
Выберете то, что вам нужно
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
Use a plastic opening tool to pry up the plastic midframe connector panel.
Remove the connector panel with a pair of tweezers.
Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket.
Place a heated iOpener on the left side of the phone for at least 90 seconds.
Reheat the iOpener and place it on the right half of the phone.
Insert the edge of an opening pick underneath the bottom right side of the front glass.
Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone.
Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply.
Slide the opening pick down along the left half of the phone stopping at the lower left corner.
Slide the opening pick all the way to the bottom left corner of the phone, making sure it is securely placed.
Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive.
Insert an opening pick under the soft button icons on the display and pry the button cables down off the inside of the front panel.
Use the sharp tip of a spudger to lift the front panel assembly cable connector straight up off its socket on the motherboard.
Safely remove the front panel assembly from phone.
Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
Two 4.4 mm Phillips #000 screws near the USB port on the battery side of the phone
One 4.4 mm Phillips #000 screw
Gently run a plastic opening tool down along the left inner side of the interior frame to separate the three white plastic clips.
Gently pull the long sides of the silver bezel out away from the phone to separate the two halves of the midframe.
Continue on to the right side of the silver bezel, pulling away from the interior section of the midframe to separate the two halves.
Use a plastic opening tool to pry any remaining corners out of the silver bezel.
Carefully remove the interior midframe/motherboard assembly from the white inner midframe.
Carefully wedge the tip of a spudger underneath the antenna cable connector.
Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
Remove the single 3.0 mm Phillips #000 screw securing the motherboard to the midframe.
Pull, but do not remove, the camera end of the motherboard up from the midframe to allow access to the connectors on the rear.
Use the flat end of a spudger to pry the daughterboard connector straight up off its socket on the motherboard.
Use the flat end of a spudger to disconnect the front-facing camera connector off its socket on the motherboard.
Remove the front-facing camera from the motherboard.
Use the flat end of a spudger to disengage the rear-facing camera connector straight up off its socket on the motherboard.
Remove the rear-facing camera from the motherboard.
87 участников успешно повторили данное руководство.
25 Комментариев
Do you know if I can put a g900p motherboard in the G900I in order to get FM radio. Cheers.
In Step 28 you will figure out that there is a second antenna cable that is brown and needs to be detached as well. It is alligned in one row with the blue antenna cable.
I want to use the motherboard from a T-Mobile galaxy s5 on an AT&T galaxy s5 I just wanted to know if it fits inside the att version because my SIM card reader is broken so I wanted to know if I could use one from T-Mobile and that it would fix and work
It would fit and work
I dropped my Galaxy S5, gps for maps, compass etc... works fine, but for Endomondo and Strava that requires a location is not working, before the problem it showed GPS signal Ready, Now it just keeps ideling looking for location (GPS), dissasemble to check for any loose connector or loose screw and found nothing, What can be wrong and how to fix it?
Regards
