Samsung Galaxy S5 Home Button Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S5 Home Button Replacement, Home Button: шаг 1, изображение 1 из 1
    • This guide is a conditional add-on to the Galaxy S5 Display Assembly guide. If you need to replace your home button but have not yet opened your device, start here.
    • The clear rubber backing of the home button assembly is lightly adhered to the back of the display. The adhesive should be easy to cut through with an opening tool. If you have trouble removing the assembly in the following steps, try heating the area using an iOpener or a hair dryer to loosen the adhesive.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Galaxy S5 Home Button Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy S5 Home Button Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy S5 Home Button Replacement: шаг 2, изображение 3 из 3
    • Insert either end of an opening tool into the gap between the white rubber backing of the home button assembly and the screen.
    • Work your way around the bottom edge of the button, gently cutting through the adhesive holding it in place.
    Спросите у FixBot
  3. Samsung Galaxy S5 Home Button Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy S5 Home Button Replacement: шаг 3, изображение 2 из 2
    • Once most of the adhesive around the bottom of the button has been broken, use your opening tool to pry it up.
    Спросите у FixBot
  4. Samsung Galaxy S5 Home Button Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy S5 Home Button Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy S5 Home Button Replacement: шаг 4, изображение 3 из 3
    • Grab the lifted portion of the home button assembly and gently pull it away from the display, tearing the rest of the adhesive.
    • As you pull the assembly away, the rubber backing may begin to separate from the home button. The home button is only connected to the rubber backing by a fragile cable, so do your best to keep them together as you pull the assembly out.
    • If you are transferring your home button to a new display, the original adhesive should be strong enough to keep it in place.
    • If the original adhesive is not strong enough to hold the button in place while you re-install the display, you can lay the button in the chassis, and then install the display over it—the display assembly will keep the button in place.
    • If you are installing a new home button, remove the plastic film covering the adhesive, then carefully align the button with the display and press it into place.
    Спросите у FixBot
Заключение
To finish reassembling your device, head back over to the Display Assembly guide!
8 человек успешно провели ремонт по этому руководству.
Taylor Dixon
Участник с: 06/26/18
72 640 Репутация
Автор 94 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 56
За всё время: 7,141
