Samsung Galaxy S8 Active Display Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S8 Active Display Replacement, SIM Tray/Card: шаг 1, изображение 1 из 2 Samsung Galaxy S8 Active Display Replacement, SIM Tray/Card: шаг 1, изображение 2 из 2
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Galaxy S8 Active Display Replacement, NFC Antenna and Charging Coil Assembly: шаг 2, изображение 1 из 3 Samsung Galaxy S8 Active Display Replacement, NFC Antenna and Charging Coil Assembly: шаг 2, изображение 2 из 3 Samsung Galaxy S8 Active Display Replacement, NFC Antenna and Charging Coil Assembly: шаг 2, изображение 3 из 3
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
    Спросите у FixBot
  3. Samsung Galaxy S8 Active Display Replacement: шаг 3, изображение 1 из 1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    Спросите у FixBot
  4. Samsung Galaxy S8 Active Display Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy S8 Active Display Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy S8 Active Display Replacement: шаг 4, изображение 3 из 3
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
    Спросите у FixBot
  5. Samsung Galaxy S8 Active Display Replacement: шаг 5, изображение 1 из 1
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
    Спросите у FixBot
  6. Samsung Galaxy S8 Active Display Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy S8 Active Display Replacement: шаг 6, изображение 2 из 2
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
    Спросите у FixBot
  7. Samsung Galaxy S8 Active Display Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy S8 Active Display Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy S8 Active Display Replacement: шаг 7, изображение 3 из 3
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
    Спросите у FixBot
  8. Samsung Galaxy S8 Active Display Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy S8 Active Display Replacement: шаг 8, изображение 2 из 2
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
    Спросите у FixBot
  9. Samsung Galaxy S8 Active Display Replacement, Loudspeaker Assembly: шаг 9, изображение 1 из 3 Samsung Galaxy S8 Active Display Replacement, Loudspeaker Assembly: шаг 9, изображение 2 из 3 Samsung Galaxy S8 Active Display Replacement, Loudspeaker Assembly: шаг 9, изображение 3 из 3
    • Remove the loudspeaker assembly using the flat end of a spudger.
    Спросите у FixBot
  10. Samsung Galaxy S8 Active Display Replacement, Display: шаг 10, изображение 1 из 2 Samsung Galaxy S8 Active Display Replacement, Display: шаг 10, изображение 2 из 2
    • Disconnect the display flex cable on the motherboard using the flat end of a spudger.
    Спросите у FixBot
  11. Samsung Galaxy S8 Active Display Replacement: шаг 11, изображение 1 из 2 Samsung Galaxy S8 Active Display Replacement: шаг 11, изображение 2 из 2
    • Place the clear side of a heated iOpener over each edge of the phone for about 90 seconds to soften the adhesive attached to the display.
    • Reheat iOpener as needed.
    • A hair dryer or heat gun can also be used to soften the adhesive. A hair dryer/heat gun will make the metal frame hot to the touch, so handle it with care.
    Спросите у FixBot
  12. Samsung Galaxy S8 Active Display Replacement: шаг 12, изображение 1 из 2 Samsung Galaxy S8 Active Display Replacement: шаг 12, изображение 2 из 2
    • Press a suction handle in the middle of the bottom half of the display.
    • Pull up on the suction cup until there is a small gap in between the display and the frame.
    • If your display is cracked, the suction cup will still pull up the display as one piece.
    Спросите у FixBot
  13. Samsung Galaxy S8 Active Display Replacement: шаг 13, изображение 1 из 1
    • Insert an opening pick into the gap between the display and the frame created by pulling up on the suction cup.
    Спросите у FixBot
  14. Samsung Galaxy S8 Active Display Replacement: шаг 14, изображение 1 из 1
    • With the opening pick, continue slicing through the adhesive around the edge of the phone.
    • Once all of the adhesive is separated, remove the display by pulling up on the suction handle.
    Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Erik Mauk
Участник с: 01/24/19
1 519 Репутация
Автор 6 руководств
Команда
Cal Poly, Team S2-G1, White Winter 2019 Участник Cal Poly, Team S2-G1, White Winter 2019
CPSU-WHITE-W19S2G1
3 членов
Автор 22 руководств
1 Комментарий к руководству
adding where to and how much of the adhesive to use when putting screen and back panel back on would be a great addition to this guide
jjustin127 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 49
За всё время: 9,564
