Введение
For the Cricket Samsung Galaxy Sol, the camera needed is an OEM CRICKET SAMSUNG GALAXY SOL SM-J321AZ rear camera. Some of the reasons you would need to replace the front camera are water damage or a cracked lens.
Выберете то, что вам нужно
Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
After you have removed all the screws, take a credit card or plastic tool to lift the screen. You will go all around the border of the phone.
After removing the grey part of the phone, you will need to remove the motherboard by detaching all the chips.
To remove the rear camera, flip the tab upward and then pull the camera straight out.
