Samsung Galaxy Watch3 Display Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Watch3 Display Replacement, Unfasten the back cover screws: шаг 1, изображение 1 из 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Samsung Galaxy Watch3 Display Replacement, Wedge open the back cover: шаг 2, изображение 1 из 2 Samsung Galaxy Watch3 Display Replacement, Wedge open the back cover: шаг 2, изображение 2 из 2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: шаг 3, изображение 1 из 3 Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: шаг 3, изображение 2 из 3 Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: шаг 3, изображение 3 из 3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Samsung Galaxy Watch3 Display Replacement, Remove the back cover: шаг 4, изображение 1 из 2 Samsung Galaxy Watch3 Display Replacement, Remove the back cover: шаг 4, изображение 2 из 2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
  5. Samsung Galaxy Watch3 Display Replacement, Unplug the display connector: шаг 5, изображение 1 из 2 Samsung Galaxy Watch3 Display Replacement, Unplug the display connector: шаг 5, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
  6. Samsung Galaxy Watch3 Display Replacement, Loosen the core assembly: шаг 6, изображение 1 из 2 Samsung Galaxy Watch3 Display Replacement, Loosen the core assembly: шаг 6, изображение 2 из 2
    • The core's plastic frame fits tightly within the watch's metal housing.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
  7. Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: шаг 7, изображение 1 из 3 Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: шаг 7, изображение 2 из 3 Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: шаг 7, изображение 3 из 3
    • Carefully thread the display flex cable through the gap on the core's plastic frame.
    • Remove the core assembly.
  8. Samsung Galaxy Watch3 Display Replacement, Push out the display: шаг 8, изображение 1 из 2 Samsung Galaxy Watch3 Display Replacement, Push out the display: шаг 8, изображение 2 из 2
    • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass."
    • Use your finger to steadily push the display down through the watch's metal housing to loosen the adhesive.
    • Lightly heating the display with a hair dryer or iOpener can help soften the adhesive.
    • Remove the display.
Заключение
If possible, turn on your device and test your repair before reassembly.
3 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
117 851 Репутация
Автор 188 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 083 руководств
Один комментарий
Any idea how to remove the rotating bezel?
Azhar Suhaimi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 31
За последние 30 дней: 158
За всё время: 8,409
