Samsung Galaxy Watch4 Classic Battery Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Watch4 Classic Battery Replacement, Power down your watch: шаг 1, изображение 1 из 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Battery Replacement, Unscrew the back cover: шаг 2, изображение 1 из 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch4 Classic Battery Replacement, Pry open the back cover: шаг 3, изображение 1 из 2 Samsung Galaxy Watch4 Classic Battery Replacement, Pry open the back cover: шаг 3, изображение 2 из 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the sensor flex cable: шаг 4, изображение 1 из 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the sensor flex cable: шаг 4, изображение 2 из 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the back cover: шаг 5, изображение 1 из 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the hall sensor flex cable: шаг 6, изображение 1 из 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the hall sensor flex cable: шаг 6, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the display flex cable: шаг 7, изображение 1 из 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the display flex cable: шаг 7, изображение 2 из 2
    • Use a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the side buttons: шаг 8, изображение 1 из 2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the side buttons: шаг 8, изображение 2 из 2
    • Use a spudger to disconnect the crown button flex cable.
  9. Samsung Galaxy Watch4 Classic Battery Replacement, Unscrew the motherboard: шаг 9, изображение 1 из 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: шаг 10, изображение 1 из 3 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: шаг 10, изображение 2 из 3 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: шаг 10, изображение 3 из 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
  11. Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: шаг 11, изображение 1 из 3 Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: шаг 11, изображение 2 из 3 Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: шаг 11, изображение 3 из 3
    • The battery is held in place with light adhesive.
    • Place the flat end of a spudger in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core assembly.
  12. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the battery: шаг 12, изображение 1 из 2 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the battery: шаг 12, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not, replace it with double sided or pre-cut adhesive tape.
    • Remove the battery.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
11 участников успешно повторили данное руководство.
Adriana Zwink
Участник с: 12/18/19
48 586 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 277 руководств
3 Комментариев
What kind of battery does it use?
Dylan - Ответить
The directions are perfect! I had very little issue following your instructions.
One point I would make is that there seems to be more of an available gap to pry the back off of the watch located between the pairs of wristband spurs where there is very little gap on the sides. After almost 20 minutes of trying to get the little plastic tool to work the back off, I looked closely at the area between the spurs and it looked more promising. A couple of probes with the tool, and the the back started right off. The rest is history. Thanks!!!
Rufus T. Montgomery - Ответить
Is there any adhesive applied for the water resistance while installation of the battery ?
Wasabi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 79
За последние 30 дней: 390
За всё время: 8,194
