Введение
Does your watch battery last less than a day with minimal use, or does the watch only power on when connected to the charger? Replacing the battery may fix these problems.
Выберете то, что вам нужно
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
Using the flat end of a spudger, pry up the motherboard.
The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, lift the battery casing.
Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
Once the battery is free, use the flat end of a spudger to lift up the battery cable.
103 человек успешно провели ремонт по этому руководству.
39 Комментарии к руководству
Excellent guidelines, and do you have steps for s3 frontier
A reference to the battery part number would be great.
Very good job and very easy
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
