Введение
This guide will demonstrate eight steps on how to replace the flip screen on a Samsung MV900F Smart Camera.
Выберете то, что вам нужно
Slide the lock towards the middle of the camera, in the same direction of the arrow.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to remove the four rubber screw covers.
Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
To reassemble your device, follow these steps in reverse order.
1 Комментарий к руководству
Anyone an Idea where I can buy a cheap new display for that cam?
