Введение
This guide details the process of replacing a dead or dying battery within the Samsung NP700Z5AH. This quick and simple process requires only two simple tools to complete.
Выберете то, что вам нужно
Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
Wedge your fingers in between the upper case and the lower case
Gently pull the lower case away from the upper case to remove it
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
Place your fingers on the corner sections of the battery.
Lift to remove the battery.
5 человек успешно провели ремонт по этому руководству.
