Введение
This guide shows how to remove and replace the evaporator fan or circulation fan in your Samsung RF28R7201SG refrigerator.
The Samsung fridge has two evaporator fans, and this guide is for the fan in the refrigerator compartment. For the freezer evaporator fan, follow this guide instead.
The evaporator fan circulates cold air from the evaporator coils into the refrigerator compartment. If your refrigerator compartment isn't cooling evenly (the back of the compartment gets much colder), you may have a faulty evaporator fan.
Выберете то, что вам нужно
Open both French doors for the refrigerator compartment.
Remove all the loose shelves and bins from the refrigerator compartment.
Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
Remove the bottom shelf.
Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
Use a Phillips screwdriver to remove the four screws securing the evaporator cover:
Two 37 mm-long screws
Two 16.5 mm-long screws
Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
Don't try to fully remove the cover in this step, as it's connected by several wires.
Squeeze and disconnect the two wire connectors connecting the evaporator cover to the refrigerator.
Use a Phillips #2 screwdriver to remove the four 18.5 mm-long screws securing the fan bracket to the evaporator cover.
Repair didn’t go as planned? Ask our Answers community for help.
2 участников успешно повторили данное руководство.
