Введение
This guide will provide a step-by-step procedure for replacing the OLED screen in your Samsung Rogue. This is one of the more difficult repair guides because it requires a lot of disassembling.
Выберете то, что вам нужно
With your thumbs, push down on the back cover of your phone and slide it away from the camera.
Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to open the four black gates by putting them in the "up" position.
With the same tweezers, carefully pull out the orange strips from the four specified gates.
In this procedure, the rubber function key pad can easily fall out, so it would be best to take it out and set it safely aside.
Starting at the top, use a plastic opening tool to pry open the protective screen on the front of the phone.
One of the strips you pulled out of a gate from a previous step is attached to the screen at the bottom. Be careful not to damage it when you are taking off the screen.
Еще один человек закончил это руководство.
