Samsung Stratosphere Flex Cable Replacement
Выберете то, что вам нужно
  1. Samsung Stratosphere Flex Cable Replacement, Battery: шаг 1, изображение 1 из 1
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Stratosphere Flex Cable Replacement: шаг 2, изображение 1 из 1
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    Спросите у FixBot
  3. Samsung Stratosphere Flex Cable Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    Спросите у FixBot
  4. Samsung Stratosphere Flex Cable Replacement: шаг 4, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    Спросите у FixBot
  5. Samsung Stratosphere Flex Cable Replacement: шаг 5, изображение 1 из 1
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    Спросите у FixBot
  6. Samsung Stratosphere Flex Cable Replacement: шаг 6, изображение 1 из 1
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    Спросите у FixBot
  7. Samsung Stratosphere Flex Cable Replacement: шаг 7, изображение 1 из 2 Samsung Stratosphere Flex Cable Replacement: шаг 7, изображение 2 из 2
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    Спросите у FixBot
  8. Samsung Stratosphere Flex Cable Replacement: шаг 8, изображение 1 из 1
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    Спросите у FixBot
  9. Samsung Stratosphere Flex Cable Replacement, Front Camera: шаг 9, изображение 1 из 1
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
    Спросите у FixBot
  10. Samsung Stratosphere Flex Cable Replacement: шаг 10, изображение 1 из 1
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
    Спросите у FixBot
  11. Samsung Stratosphere Flex Cable Replacement: шаг 11, изображение 1 из 1
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
    Спросите у FixBot
  12. Samsung Stratosphere Flex Cable Replacement: шаг 12, изображение 1 из 1
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
    Спросите у FixBot
  13. Samsung Stratosphere Flex Cable Replacement: шаг 13, изображение 1 из 1
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
    Спросите у FixBot
  14. Samsung Stratosphere Flex Cable Replacement: шаг 14, изображение 1 из 1
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
    Спросите у FixBot
  15. Samsung Stratosphere Flex Cable Replacement: шаг 15, изображение 1 из 2 Samsung Stratosphere Flex Cable Replacement: шаг 15, изображение 2 из 2
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
    Спросите у FixBot
  16. Samsung Stratosphere Flex Cable Replacement: шаг 16, изображение 1 из 1
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
    Спросите у FixBot
  17. Samsung Stratosphere Flex Cable Replacement: шаг 17, изображение 1 из 2 Samsung Stratosphere Flex Cable Replacement: шаг 17, изображение 2 из 2
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
    Спросите у FixBot
  18. Samsung Stratosphere Flex Cable Replacement, Flex Cable: шаг 18, изображение 1 из 1
    • Carefully peel the blue tape from the bottom of the flex cable and set it aside.
    Спросите у FixBot
  19. Samsung Stratosphere Flex Cable Replacement: шаг 19, изображение 1 из 2 Samsung Stratosphere Flex Cable Replacement: шаг 19, изображение 2 из 2
    • Use one of the plastic opening tools to loosen the flex cable from its central housing.
    • Pull lightly on the flex cable to free it from the housing.
    • The cable may audibly snap as it is freed from its attachment.
    Спросите у FixBot
  20. Samsung Stratosphere Flex Cable Replacement: шаг 20, изображение 1 из 1
    • Use tweezers to loosen the flex cable and speaker from the bottom of the phone.
    • Pull upward with the tweezers and the flex cable will come loose.
    • The flex cable will come free with the front-facing camera attached. In order to remove the front-facing camera, see our guide here.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Jonathan Oyan
Участник с: 10/18/13
624 Репутация
1 руководство автора
Команда
Cal Poly, Team 11-32, Amido Fall 2013 Участник Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 40
За всё время: 1,689
