Samsung Stratosphere Rear Camera Replacement
Выберете то, что вам нужно
    1. Samsung Stratosphere Rear Camera Replacement, Battery: шаг 1, изображение 1 из 1
      • Using your fingers, pry along the groove at the top of the phone.
      • Pull back on the rear casing until it comes free from the device.
      • The casing will make a cracking sound as it is removed.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Stratosphere Rear Camera Replacement: шаг 2, изображение 1 из 1
      • With your fingers, pry from the bottom of the battery to loosen it.
      • Lift away to remove the battery from the phone.
      Спросите у FixBot
    1. Samsung Stratosphere Rear Camera Replacement, Motherboard: шаг 3, изображение 1 из 1
      • Locate the red and white sim card located above the battery housing.
      • Remove the sim card by sliding it downwards from its slot with your fingers.
      Спросите у FixBot
    2. Samsung Stratosphere Rear Camera Replacement: шаг 4, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
      • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
      Спросите у FixBot
    3. Samsung Stratosphere Rear Camera Replacement: шаг 5, изображение 1 из 1
      • Pry around the rear panel with a plastic opening tool to loosen it.
      • Prying too deeply may damage delicate components inside the phone.
      • Remove the rear panel from the phone with your fingers.
      Спросите у FixBot
    4. Samsung Stratosphere Rear Camera Replacement: шаг 6, изображение 1 из 1
      • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
      Спросите у FixBot
    5. Samsung Stratosphere Rear Camera Replacement: шаг 7, изображение 1 из 2 Samsung Stratosphere Rear Camera Replacement: шаг 7, изображение 2 из 2
      • Locate the flex cable attachment at the tab with a green arrow printed on top.
      • Pry from the side the arrow is pointing with your fingers.
      • The cable will audibly snap as it is removed from its attachment.
      • Let the cable hang loosely to the side of the phone.
      Спросите у FixBot
    6. Samsung Stratosphere Rear Camera Replacement: шаг 8, изображение 1 из 1
      • Pull the motherboard up from the side opposite the loose flex cable.
      • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
      • Lift to remove the motherboard from the device.
      Спросите у FixBot
    1. Samsung Stratosphere Rear Camera Replacement, Rear Camera: шаг 9, изображение 1 из 1
      • Gently pull the camera to the left while keeping it as close to the motherboard as possible.
      • The metal foil connector attached to the camera should slide out of the motherboard.
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Ryan
Участник с: 10/20/13
375 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-32, Amido Fall 2013 Участник Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 членов
Автор 54 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 1,006
