Scanner Head Replacement
Выберете то, что вам нужно
  1. Scanner Head Replacement, Remove Back Panel: шаг 1, изображение 1 из 1
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. Scanner Head Replacement, Remove Inner Back Pannel: шаг 2, изображение 1 из 2 Scanner Head Replacement, Remove Inner Back Pannel: шаг 2, изображение 2 из 2
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. Scanner Head Replacement, Remove Upper Portion: шаг 3, изображение 1 из 2 Scanner Head Replacement, Remove Upper Portion: шаг 3, изображение 2 из 2
    • Press down on the two plastic hinges to remove the upper portion of printer.
  4. Scanner Head Replacement, Unplug Speaker Wire: шаг 4, изображение 1 из 1
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. Scanner Head Replacement, Removing Scanner Tray: шаг 5, изображение 1 из 2 Scanner Head Replacement, Removing Scanner Tray: шаг 5, изображение 2 из 2
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. Scanner Head Replacement, Removing Scanner Tray - cont.: шаг 6, изображение 1 из 1
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
  7. Scanner Head Replacement: шаг 7, изображение 1 из 1
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. Scanner Head Replacement: шаг 8, изображение 1 из 1
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. Scanner Head Replacement, Detaching the Scanner Tray: шаг 9, изображение 1 из 1
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  10. Scanner Head Replacement, Detaching the Scanner Head: шаг 10, изображение 1 из 2 Scanner Head Replacement, Detaching the Scanner Head: шаг 10, изображение 2 из 2
    • Detach the white ribbon wire from the scanner head by pulling gently at the connection.
  11. Scanner Head Replacement, Removing the Scanner Head: шаг 11, изображение 1 из 2 Scanner Head Replacement, Removing the Scanner Head: шаг 11, изображение 2 из 2
    • Lift the gray drive belt from the black tab to disconnect the drive belt from the scanner head.
    • Remove the scanner head from the scanner by gently rotating and then lifting.
  12. Scanner Head Replacement, Adding New Scanner Head: шаг 12, изображение 1 из 2 Scanner Head Replacement, Adding New Scanner Head: шаг 12, изображение 2 из 2
    • Place the new scanner head in the scanner tray by fastening the drive belt into the black tab.
    • Make sure the tab on the outer portion of the gray drive belt is fastened.
    • Once the drive belt is secured, rotate the scanner head back into position.
    • Re-attach the white ribbon wire to the connection from Step 10.
Заключение
3 человек успешно провели ремонт по этому руководству.
Mackenzie Billings
Участник с: 04/05/11
577 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 12-31, Maness Spring 2011 Участник Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 членов
Автор 9 руководств
2 Комментарии к руководству
Ok, but where do I purchase a new scanner head???
Nichelle King - Ответить Поделиться
the step between 9 and 10 doesn't seem to make sense. it never established that the scanner head is broken...I couldn't identify where step 10 scanner head came up ...no where did it show the scanner between step 1 and step 9...Please offer an explanation...
by step 9 the scanner package had already removed...i m afraid I wont here from ifixit because the printer is about 20 years old.
winston ho - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 19
За последние 30 дней: 73
За всё время: 12,555
