Введение
The microphone capsule is the main part that makes the microphone work. It is essential that this part is functioning properly.
Выберете то, что вам нужно
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
Slowly, pull upward while twisting the black plastic piece clockwise.
Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
Once installed, reassemble the microphone following the steps in reverse.
9 человек успешно провели ремонт по этому руководству.
5 Комментарии к руководству
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
You can unscrew just the grill.
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
