Введение
Screens can crack or wear out so you need to change the screen.
Выберете то, что вам нужно
Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
Unlatch the two clips located at the top of the device that hold the motherboard in place.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Еще один человек закончил это руководство.
