Sony Alpha NEX-6 Back Case Replacement
Выберете то, что вам нужно
  1. Sony Alpha NEX-6 Back Case Replacement, Battery: шаг 1, изображение 1 из 1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
    Спросите у FixBot
    Добавить комментарий
  2. Sony Alpha NEX-6 Back Case Replacement: шаг 2, изображение 1 из 1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
    Спросите у FixBot
  3. Sony Alpha NEX-6 Back Case Replacement: шаг 3, изображение 1 из 1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
    Спросите у FixBot
  4. Sony Alpha NEX-6 Back Case Replacement, Battery compartment screws: шаг 4, изображение 1 из 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
    Спросите у FixBot
  5. Sony Alpha NEX-6 Back Case Replacement, Bottom screws: шаг 5, изображение 1 из 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
    Спросите у FixBot
  6. Sony Alpha NEX-6 Back Case Replacement, Side screws: шаг 6, изображение 1 из 1
    • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
    • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
    Спросите у FixBot
  7. Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: шаг 7, изображение 1 из 2 Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: шаг 7, изображение 2 из 2
    • Starting with the battery compartment gently begin to separate the back case front the camera.
    • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
    • Gently lift the back case away from the camera an slide it down to completely remove the back case.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Clayton Dale
Участник с: 01/20/15
1 067 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 11-2, Blackwell Winter 2015 Участник USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 членов
Автор 14 руководств
3 Комментарии к руководству
At {STEP 7} you will notice the last parts to release are the flash button / record button areas. This is particularly tricky.
The flash button release seems to be attached inside, so take care. In my case I did not remove the back case completely due to this.
The corner where the record button is requires extra force to slide down / pry out.
Re-assembly : Take note of these parts.
- the PLAY button flexible circuit has a small hole which fits into a pin on the back case. It is important to align this correctly or your play & AEL button may not function.
- The eye piece has a flexible circuit on its right side which tucks behind a small tab - take care this is not dislodged or it could be damaged when re assembling.
Riquez JP - Ответить Поделиться
Does your team know how to fix the Flash Pop-up button ? It seems the flash for me and others is stuck open and can't be clicked back down. Can you assist ?
rullor - Ответить Поделиться
Can you please let me know how to replace the battery door? Thank you.
Richard Bullough - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 68
За всё время: 4,694
