Sony Alpha NEX-6 Control Wheel Replacement
Выберете то, что вам нужно
  1. Sony Alpha NEX-6 Control Wheel Replacement, Battery: шаг 1, изображение 1 из 1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
    Спросите у FixBot
    Добавить комментарий
  2. Sony Alpha NEX-6 Control Wheel Replacement: шаг 2, изображение 1 из 1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
    Спросите у FixBot
  3. Sony Alpha NEX-6 Control Wheel Replacement: шаг 3, изображение 1 из 1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
    Спросите у FixBot
  4. Sony Alpha NEX-6 Control Wheel Replacement, Battery compartment screws: шаг 4, изображение 1 из 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
    Спросите у FixBot
  5. Sony Alpha NEX-6 Control Wheel Replacement, Bottom screws: шаг 5, изображение 1 из 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
    Спросите у FixBot
  6. Sony Alpha NEX-6 Control Wheel Replacement, Side screws: шаг 6, изображение 1 из 1
    • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
    • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
    Спросите у FixBot
  7. Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: шаг 7, изображение 1 из 2 Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: шаг 7, изображение 2 из 2
    • Starting with the battery compartment gently begin to separate the back case front the camera.
    • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
    • Gently lift the back case away from the camera an slide it down to completely remove the back case.
    Спросите у FixBot
  8. Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: шаг 8, изображение 1 из 2 Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: шаг 8, изображение 2 из 2
    • Pry out the ribbon cable by carefully pushing on its side tabs with a spudger.
    Спросите у FixBot
  9. Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: шаг 9, изображение 1 из 2 Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: шаг 9, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Using a spudger, lift the metal locking tab located at the top right corner of control wheel assembly.
    • Using tweezers, carefully slide the assembly up to release it.
    Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Clayton Dale
Участник с: 01/20/15
1 067 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 11-2, Blackwell Winter 2015 Участник USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 членов
Автор 14 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 62
За всё время: 6,008
