Введение
This guide shows how to replace the disc drive in the Sony BDP-S3700.
Выберете то, что вам нужно
Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
Remove the back of the device by slowly sliding the rear outer housing backwards.
Flip the Blu-ray back up
Remove the three ribbon cables that connect the disc drive to the motherboard.
Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
3 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
do you know how I can find a replacement power socket for the pcb on a sony bluray player like the one on this item?
It is the yellow colored socket on this model and still used on most Sony players still in production that use an external AC adapter.
Bei mein dvd Player geht das Netflix nicht und ich habe keine dvd da zu bekommen
