Введение
In the event that the microphone components stop working and there is no audio in the video camera's recordings, it is necessary to access the inner workings of the microphone. This guide shows how to get to these parts, by disassembling all of the surroundings of the camera and prying out the microphone components.
Выберете то, что вам нужно
Press the battery release button.
While pushing the battery button, slide the battery to the left.
Open the cassette cover.
Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
Remove the single 4.5 mm screw from the backside.
Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using metal tweezers, pull out the plastic connector box on the front side.
Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
Unscrew the blue screw behind microphone and remove it from the video camera 1x3.6mm.
With the plastic removal tool, pry up the microphone housing units. This will allow access to the camcorder microphone.
