Введение
If your device is not turning on and you're using batteries as a power source, you can use this guide to remove or replace the batteries. Be sure to remove the batteries and unplug the device before taking it apart to avoid electric shock.
Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
