Выберете то, что вам нужно
Slide the battery latch down the side of the camera with your hands.
The latch will automatically pop open.
Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Once the screws are removed, slowly remove the back casing from the rest of the camera.
Dislodge the round casing from the lens.
Pull it away from the rest of the camera.
Work the back panel out from under the small grey clip.
Slide the back panel off of the camera by dislodging it from the remaining clips.
Below is a flat, orange cable connecting the lens to the motherboard.
Turn the camera over so that you can see the front of the lens.
Two connectors link the lens to the motherboard.
Gently bring the lens away from the camera.
Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
Gently pull out the cables and move the lens away from the rest of the camera.
You should now have two distinct, separate components.
Pull off the top button piece. You will have to detach a small blue ribbon cable.
Remove the flash mechanism. It is held in place by a clip on the side of the camera.
The capacitor and flash will rotate out, still attached by a ribbon cable on the left.
Lift up the black tab with the spudger.
Gently remove the ribbon cable from the rest of the camera.
The flash component is now completely separate from the rest of the camera.
