Sony DVP-SR200P Processing Board Replacement
Выберете то, что вам нужно
    1. Sony DVP-SR200P Processing Board Replacement, Top Cover: шаг 1, изображение 1 из 2 Sony DVP-SR200P Processing Board Replacement, Top Cover: шаг 1, изображение 2 из 2
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      Спросите у FixBot
      Добавить комментарий
    2. Sony DVP-SR200P Processing Board Replacement: шаг 2, изображение 1 из 2 Sony DVP-SR200P Processing Board Replacement: шаг 2, изображение 2 из 2
      • Slide the cover away from the front of the DVD player until it is off.
      Спросите у FixBot
    1. Sony DVP-SR200P Processing Board Replacement, Processing Board: шаг 3, изображение 1 из 1
      • Remove the blue tape from the processing board by gently pulling upward.
      Спросите у FixBot
    2. Sony DVP-SR200P Processing Board Replacement: шаг 4, изображение 1 из 2 Sony DVP-SR200P Processing Board Replacement: шаг 4, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      Спросите у FixBot
    3. Sony DVP-SR200P Processing Board Replacement: шаг 5, изображение 1 из 1
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      Спросите у FixBot
    4. Sony DVP-SR200P Processing Board Replacement: шаг 6, изображение 1 из 1
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Brian Hua
Участник с: 01/11/13
80 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-17, Forte Winter 2013 Участник Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 членов
Автор 18 руководств
3 Комментарии к руководству
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - Ответить Поделиться
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
My DVD player not run but power on Bluetooth not connect
Sony - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 46
За всё время: 2,382
