Sony M-430 Microcassette-Corder Back Cover Replacement
Выберете то, что вам нужно
    1. Sony M-430 Microcassette-Corder Back Cover Replacement, Battery: шаг 1, изображение 1 из 1
      • Find the arrow on the battery cover on the back of the device.
      • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
      Спросите у FixBot
      Добавить комментарий
    2. Sony M-430 Microcassette-Corder Back Cover Replacement: шаг 2, изображение 1 из 2 Sony M-430 Microcassette-Corder Back Cover Replacement: шаг 2, изображение 2 из 2
      • Lift the cover and remove the batteries.
      Спросите у FixBot
    1. Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: шаг 3, изображение 1 из 2 Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: шаг 3, изображение 2 из 2
      • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
      • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
      • Potential for device damage: be careful not to apply too much force, as the lid may break.
      Спросите у FixBot
    2. Sony M-430 Microcassette-Corder Back Cover Replacement: шаг 4, изображение 1 из 2 Sony M-430 Microcassette-Corder Back Cover Replacement: шаг 4, изображение 2 из 2
      • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
      • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
      Спросите у FixBot
    3. Sony M-430 Microcassette-Corder Back Cover Replacement: шаг 5, изображение 1 из 1
      • Use a spudger to push in the two tabs located on the bottom of the device.
      • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
      Спросите у FixBot
    4. Sony M-430 Microcassette-Corder Back Cover Replacement: шаг 6, изображение 1 из 1
      • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
      • The back cover should lift cleanly off.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Matt Teare
Участник с: 01/20/12
35 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 10-34, Amido Winter 2012 Участник Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 членов
Автор 70 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 36
За всё время: 2,703
