Sony NEX-7 Lens Mount Replacement
Выберете то, что вам нужно
    1. Sony NEX-7 Lens Mount Replacement, Battery: шаг 1, изображение 1 из 2 Sony NEX-7 Lens Mount Replacement, Battery: шаг 1, изображение 2 из 2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Спросите у FixBot
      Добавить комментарий
    2. Sony NEX-7 Lens Mount Replacement: шаг 2, изображение 1 из 1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Спросите у FixBot
    3. Sony NEX-7 Lens Mount Replacement: шаг 3, изображение 1 из 1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Спросите у FixBot
    1. Sony NEX-7 Lens Mount Replacement, SD card: шаг 4, изображение 1 из 1
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      Спросите у FixBot
    1. Sony NEX-7 Lens Mount Replacement, Lens: шаг 5, изображение 1 из 2 Sony NEX-7 Lens Mount Replacement, Lens: шаг 5, изображение 2 из 2
      • First, turn the camera upside down.
      • Press the button located next to silver lens mount and rotate the lens counterclockwise.
      • Pull the lens away from the camera body.
      • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
      Спросите у FixBot
    1. Sony NEX-7 Lens Mount Replacement, Lens Mount: шаг 6, изображение 1 из 1
      • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
      Спросите у FixBot
    2. Sony NEX-7 Lens Mount Replacement: шаг 7, изображение 1 из 1
      • Remove these three layers from the lens mount with your finger or by turning the camera face down.
      Спросите у FixBot
    3. Sony NEX-7 Lens Mount Replacement: шаг 8, изображение 1 из 1
      • Remove the two newly visible #00 screws within the metal ring.
      Спросите у FixBot
    4. Sony NEX-7 Lens Mount Replacement: шаг 9, изображение 1 из 1
      • Remove the final metal ring from the mount.
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Jay Miley
Участник с: 04/22/14
5 453 Репутация
Автор 13 руководств
Команда
Cal Poly, Team 10-55, Amido Spring 2014 Участник Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 членов
Автор 46 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 38
За всё время: 3,027
