Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks Replacement
Выберете то, что вам нужно
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Back Panel: шаг 1, изображение 1 из 1
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      Спросите у FixBot
      Добавить комментарий
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 2, изображение 1 из 1
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      Спросите у FixBot
    3. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 3, изображение 1 из 1
      • This is what the device should look like once the back cover panel has been removed.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Battery: шаг 4, изображение 1 из 1
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 5, изображение 1 из 1
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Inner Casing: шаг 6, изображение 1 из 1
      • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 7, изображение 1 из 1
      • Pry open the black casing to access the screw that is holding down the battery holder.
      • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
      • Lift the black inner casing and the battery holder out of the device.
      • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Power Button: шаг 8, изображение 1 из 1
      • Remove the stylus from the device.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 9, изображение 1 из 3 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 9, изображение 2 из 3 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 9, изображение 3 из 3
      • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
      • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
      • Pry apart off the top panel of the device.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Side and Bottom Panel: шаг 10, изображение 1 из 2 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Side and Bottom Panel: шаг 10, изображение 2 из 2
      • Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
      • Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 11, изображение 1 из 2 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 11, изображение 2 из 2
      • Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Motherboard: шаг 12, изображение 1 из 1
      • Using a Phillips head screwdriver, remove the one 1.4 mm screw holding in the motherboard.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 13, изображение 1 из 2 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 13, изображение 2 из 2
      • Using the flat end of the spudger, flip up the 4 latches holding down the thin, orange strips that connect the motherboard to the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports.
      • To disconnect the the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports pull each orange slip away from their corresponding latch.
      Спросите у FixBot
    3. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 14, изображение 1 из 2 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 14, изображение 2 из 2
      • Lift the end of the motherboard closest to the memory cards and pull out.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, SD and Pro Duo Memory Cards Holder: шаг 15, изображение 1 из 1
      • Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the memory card holder.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 16, изображение 1 из 1
      • Using the flat end of the spudger, pry open the brown flap that connects the cardholder to the motherboard.
      Спросите у FixBot
    3. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 17, изображение 1 из 2 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 17, изображение 2 из 2
      • Pull the orange strip out of the opened brown flap.
      • Remove the memory card holder.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Screen: шаг 18, изображение 1 из 2 Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Screen: шаг 18, изображение 2 из 2
      • Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the SD/memory card holder.
      • Remove the SD/memory card holder from the device.
      Спросите у FixBot
    2. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 19, изображение 1 из 1
      • Using the Phillips head screwdriver, remove the two 1.4 mm screws in the screen at the bottom of the device that are usually covered by the power switch panel.
      Спросите у FixBot
    3. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 20, изображение 1 из 1
      • Using the same screwdriver, remove the 1.4 mm screw at the bottom of the device that is usually covered by the bottom and side panel.
      Спросите у FixBot
    4. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 21, изображение 1 из 1
      • Remove the four 1.4 mm screws that are located on the side of the device that are usually covered by the bottom and side panel.
      Спросите у FixBot
    5. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 22, изображение 1 из 1
      • Be sure to lift the thin, orange strip that is attached to the audio/AC/mini USB ports out of the way, before removing the screen.
      Спросите у FixBot
    6. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement: шаг 23, изображение 1 из 1
      • Lift the end of screen opposite the red edge and pull it out of the casing.
      Спросите у FixBot
    1. Sony Reader Touch Edition PRS-600 Audio/Micro USB/AC Adapter Jacks  Replacement, Audio/Micro USB/AC Adapter Jacks: шаг 24, изображение 1 из 1
      • Remove the two 1.4 mm screws that are located on the audio/AC adapter/mini USB ports.
      • Lift up and remove the audio/micro USB/ AC adapter jacks.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Terrika Ngobili
Участник с: 10/13/14
873 Репутация
Автор 7 руководств
Команда
Clemson, Team 1-4, Benson Fall 2014 Участник Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 членов
Автор 22 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 33
За последние 30 дней: 64
За всё время: 1,326
