Введение
In this guide we will be taking the Sony Smart Watch SW2 watch out of its housing to remove its screen in order to reach the interior components. This process will only require a small tool with a flat edge.
Выберете то, что вам нужно
Detach the smart watch from the band by pushing on the back of the watch housing.
Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
To reassemble your device, follow these steps in reverse order.
3 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
whwre can I get the LCD screen for SW2?
