Sony Vaio PCG-F420 Display Replacement
Выберете то, что вам нужно
  1. Sony Vaio PCG-F420 Display Replacement, Battery: шаг 1, изображение 1 из 1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
    Спросите у FixBot
    Добавить комментарий
  2. Sony Vaio PCG-F420 Display Replacement: шаг 2, изображение 1 из 1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
    Спросите у FixBot
  3. Sony Vaio PCG-F420 Display Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
    Спросите у FixBot
  4. Sony Vaio PCG-F420 Display Replacement: шаг 4, изображение 1 из 1
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
    Спросите у FixBot
  5. Sony Vaio PCG-F420 Display Replacement: шаг 5, изображение 1 из 1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
    Спросите у FixBot
  6. Sony Vaio PCG-F420 Display Replacement: шаг 6, изображение 1 из 1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
    Спросите у FixBot
  7. Sony Vaio PCG-F420 Display Replacement: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
    Спросите у FixBot
  8. Sony Vaio PCG-F420 Display Replacement: шаг 8, изображение 1 из 2 Sony Vaio PCG-F420 Display Replacement: шаг 8, изображение 2 из 2
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
    Спросите у FixBot
  9. Sony Vaio PCG-F420 Display Replacement: шаг 9, изображение 1 из 1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
    Спросите у FixBot
  10. Sony Vaio PCG-F420 Display Replacement, Display: шаг 10, изображение 1 из 1
    • Use tweezers to remove the rubber covers on the four screws at the corners near the display.
    Спросите у FixBot
  11. Sony Vaio PCG-F420 Display Replacement: шаг 11, изображение 1 из 1
    • With the screwdriver, unscrew the four screws that attached the front bezel panel with the display assembly, as shown in the image.
    Спросите у FixBot
  12. Sony Vaio PCG-F420 Display Replacement: шаг 12, изображение 1 из 1
    • Using a spudger or another flat-headed tool, pry away the front bezel panel from the display assembly.
    • Apply pressure carefully while placing the spudger on the seam connecting the front and rear bezels.
    • Clips attaching the two panels should start to come apart.
    Спросите у FixBot
  13. Sony Vaio PCG-F420 Display Replacement: шаг 13, изображение 1 из 3 Sony Vaio PCG-F420 Display Replacement: шаг 13, изображение 2 из 3 Sony Vaio PCG-F420 Display Replacement: шаг 13, изображение 3 из 3
    • There are a total of 14 clips holding the two bezel panels together. Be careful when unclipping all of them.After all the clips are off, the bezel will just pop right off the display panel.
    • Remove all 14 clips and place them in a safe area.
    • Once all 14 clips are removed the bezel can be removed.
    Спросите у FixBot
  14. Sony Vaio PCG-F420 Display Replacement: шаг 14, изображение 1 из 1
    • Find and unscrew the four gold Philips-head screws that attach the display to the rear bezel of the display assembly.
    • Take care not to immediately remove the display, as cables are still attached.
    Спросите у FixBot
  15. Sony Vaio PCG-F420 Display Replacement: шаг 15, изображение 1 из 2 Sony Vaio PCG-F420 Display Replacement: шаг 15, изображение 2 из 2
    • Locate the ribbon cable slot and the two-pin backlight cable. These are essential connections for the display.
    • Gently, but firmly, grasp the ribbon cable near its connection point.
    • Use steady, even pressure to pull the ribbon cable out of its socket. Be careful not to use excessive force.
    • Similarly, disconnect the two-pin backlight cable with gentle and controlled force. Ensure you disconnect both cables securely to avoid any damage during removal.
    Спросите у FixBot
Заключение
Therin Irwin
Участник с: 04/19/10
22 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 29-77, Johann Spring 2010 Участник Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 35
За всё время: 3,168
