Sony Xperia ZL Battery Replacement
Выберете то, что вам нужно
  1. Sony Xperia ZL Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Place the phone face down.
    Спросите у FixBot
    Добавить комментарий
  2. Sony Xperia ZL Battery Replacement: шаг 2, изображение 1 из 1
    • At the bottom of the phone will be a cover that flips open. A sticker will be under and when the sticker is peeled back, two screws will be revealed. Use a JIS J00 screw head to unscrew.
    Спросите у FixBot
  3. Sony Xperia ZL Battery Replacement: шаг 3, изображение 1 из 1
    • Once the two screws have been removed. Take the prying tool to pry off the back cover of the phone. Next take a JIS J00 screwhead and unscrew the 5 screws that are located in the photo.
    Спросите у FixBot
  4. Sony Xperia ZL Battery Replacement: шаг 4, изображение 1 из 1
    • After the screws have been taken out, carefully disconnect the 7 indicated connectors using a small plastic opening tool or spudger.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    Спросите у FixBot
  5. Sony Xperia ZL Battery Replacement: шаг 5, изображение 1 из 1
    • The last connector is located under the black sticker. Peel back the black sticker and disconnect the last connector.
    Спросите у FixBot
  6. Sony Xperia ZL Battery Replacement: шаг 6, изображение 1 из 1
    • Once all the connectors have been disconnected. You will want to use a small prying tool to pry out the back camera and all its components from the phone.
    Спросите у FixBot
  7. Sony Xperia ZL Battery Replacement: шаг 7, изображение 1 из 1
    • Remove the electrical panel with a plastic opening tool.
    Спросите у FixBot
  8. Sony Xperia ZL Battery Replacement: шаг 8, изображение 1 из 1
    • Take a small plastic prying tool and pry out the battery of the phone. The battery has adhesive tape that connects it to the phone which makes it difficult to pry out. Make sure to try prying from different angles of the battery.
    • Use a plastic prying tool when taking out the battery because any puncture within the battery could cause a fire.
    Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Liam Kanaley
Участник с: 11/03/15
433 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 Участник UMass Dartmouth, Team 1-7, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G7
3 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 32
За всё время: 2,097
