Введение
Replacing the battery requires opening up the speaker and unscrewing the bottom and upper part of the speaker. You will need a Phillips screw driver, blue plastic opening tool and a new battery.
Выберете то, что вам нужно
Place the speaker on a flat surface.
Take your blue plastic opening tool and remove the outside cover.
Reorient the speaker so the black panel is facing up.
Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
Now remove the plate.
Reorient the speaker so the bottom is facing up.
Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
Now open the plate.
With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
Reorient the speaker so the back side is facing up.
Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
Loop the battery wires through the opening in the back plate.
The battery and it's connective wires have been completely removed from the speaker.
12 человек успешно провели ремонт по этому руководству.
9 Комментарии к руководству
Please provide the source to buy the replacement battery
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
They don't sell batteries!!
It says above that battery not for sale.
A simple online search and you will find the battery.
