Step Guide To Install KDZ Firmware Using LG Flash Tool
    • Download the LG flash tool from lgflash.com and extract it on your Windows PC and launch the application
    Спросите у FixBot
    Добавить комментарий
    • Boot your mobile device into download mode by power of the device and holding the Volume Up button.
    Спросите у FixBot
    • Connet it to the pc using a proper USB cable.
    Спросите у FixBot
    • Then it is the time for you to load the kdz firmware file into LG Flash Tool window on your PC. Click on the browse button at the end of the 'Select KDZ file' line.
    Спросите у FixBot
    • Once you selected the KDZ file Click on CSE Flash button to start the flashing process Remember: The application consists of two different flashing options as CSE and Normal. CSE method wipes away the all the date available on your device But the normal method does not. If you want to upgrade from a stock firmware, selest normal
    Спросите у FixBot
    • Hit on the start button to proceed. it may be asked for administrator permissions for some LG program on your PC, if just accept it. Select the appropriate language.
    Спросите у FixBot
    • Keep in mind not to tick the Smartphone upgrade checkbox, it’s for Windows Mobile phones, not your LG device running on Android. Finally, You can start the flashing process. Wait Until it does 100%.
    Спросите у FixBot
Заключение
15 человек успешно провели ремонт по этому руководству.
Ana Schumacher
Участник с: 07/06/18
744 Репутация
1 руководство автора
1 Комментарий к руководству
Got a step by step to downgrade to 10 from 13 on the LG v60 thinq 5g? Phone is from ATT
Keith Kilpatrick - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 63
За последние 30 дней: 367
За всё время: 31,003
