Введение
In this guide, you will open up the tablet, disconnect the display ribbons from the motherboard, and remove the battery.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Carefully remove the touch screen tape sensors using tweezers in order to separate the two halves.
You will need to desolder the battery from the motherboard. Once its off you just solder the new battery in its place.
