Tabby Kidz Screen Replacement
Выберете то, что вам нужно
  1. Tabby Kidz Screen Replacement, Dismantling the tablet.: шаг 1, изображение 1 из 3 Tabby Kidz Screen Replacement, Dismantling the tablet.: шаг 1, изображение 2 из 3 Tabby Kidz Screen Replacement, Dismantling the tablet.: шаг 1, изображение 3 из 3
    • Gently insert a metal wedge into the crease on the side of the tablet.
    • Use a plastic prying tool to crack the side of the tablet open.
    • Be careful when you do this. You should not use excessive force as there are wires connecting the speaker in the back of the tablet and the front side of the tablet.
    • Once you have opened the tablet, use a plastic prying tool in order to remove the speaker in the backside of the tablet. This will enable you to properly separate both sides of the tablet.
    Спросите у FixBot
    Добавить комментарий
  2. Tabby Kidz Screen Replacement, Securing the ribbon wire.: шаг 2, изображение 1 из 1
    • There are ribbon wires on the sides of tablet. You will need to unhook the ribbon wires attached to the screen in order to secure them from tearing. The ribbon wires connect the mother board and the screen.
    • The ribbon wires are very delicate. Use extreme caution or else they might tear.
    Спросите у FixBot
  3. Tabby Kidz Screen Replacement, Removing the screws attaching the motherboard to the tablet.: шаг 3, изображение 1 из 1
    • There are 3 Ph 00 screws (4 mm long) that connect the motherboard to the tablet. These screws are indicated in the image by special markers. Once you have located these screws, unscrew them.
    Спросите у FixBot
  4. Tabby Kidz Screen Replacement, Removing the inner screen: шаг 4, изображение 1 из 3 Tabby Kidz Screen Replacement, Removing the inner screen: шаг 4, изображение 2 из 3 Tabby Kidz Screen Replacement, Removing the inner screen: шаг 4, изображение 3 из 3
    • In order to remove the inner screen, you must first unscrew the screws connecting the screen to the tablet using a ph 00 screw driver. The screws are 3mm in length.
    • Next, using a prying tool, gently remove the inner screen.
    • DO NOT try to separate the inner screen from the motherboard in this step.
    Спросите у FixBot
  5. Tabby Kidz Screen Replacement, Replacing the broken screen.: шаг 5, изображение 1 из 1
    • Install new screen for your tablet.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Mohamed
Участник с: 01/26/15
65 Репутация
Автор 2 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 6
За последние 30 дней: 31
За всё время: 786
