Teenage Engineering OP-1 Battery Replacement
Выберете то, что вам нужно
    1. Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: шаг 1, изображение 1 из 3 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: шаг 1, изображение 2 из 3 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: шаг 1, изображение 3 из 3
      • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
      • Lift the back panel and remove it. The Connector Board is revealed.
      • Disconnect the flex connector by lifting it up with a spudger.
      Спросите у FixBot
      Добавить комментарий
    1. Teenage Engineering OP-1 Battery Replacement, key removal: шаг 2, изображение 1 из 3 Teenage Engineering OP-1 Battery Replacement, key removal: шаг 2, изображение 2 из 3 Teenage Engineering OP-1 Battery Replacement, key removal: шаг 2, изображение 3 из 3
      • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
      • The four longer keys from the fingerboard are to be handled from the left side to get them off.
      • The eight smaller keys need to be levered from the bottom up.
      Спросите у FixBot
    2. Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: шаг 3, изображение 1 из 2 Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: шаг 3, изображение 2 из 2
      • The scissor mechanism of the eight small keys are obstructing the underlying screws.
      • By using again an opening tool or opening pick these can be snapped off easily.
      • When reassembling be sure to place them in with the correct side facing upwards.
      Спросите у FixBot
    3. Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: шаг 4, изображение 1 из 3 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: шаг 4, изображение 2 из 3 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: шаг 4, изображение 3 из 3
      • Loosen those 12 screws with a Phillips #00 screwdriver.
      • Then just pull off the four rotary knobs and the volume knob.
      • Now it is possible to slightly lift the keyboard and set it back.
      Спросите у FixBot
    1. Teenage Engineering OP-1 Battery Replacement, battery removal: шаг 5, изображение 1 из 3 Teenage Engineering OP-1 Battery Replacement, battery removal: шаг 5, изображение 2 из 3 Teenage Engineering OP-1 Battery Replacement, battery removal: шаг 5, изображение 3 из 3
      • Carefully pull out the connector cable from the connector board and bend it out of the way.
      • Disconnect the battery with a spudger. The connector needs to be lifted up and not being pulled to the side.
      • Now you can pry out the battery which is glued in with double sided adhesive tape.
      Спросите у FixBot
Заключение
16 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
134 546 Репутация
Автор 189 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 307 руководств
44 Комментарии к руководству
This is great. What type of battery is the replacement?? thanks!
TrustNoShadows - Ответить Поделиться
Hi, thanks for the question. I added another picture and put some information in the introduction.
Tobias Isakeit - Ответить Поделиться
hey, thanks for this! is the battery plug simple JST or do I need to get something specific?
lfsaw - Ответить Поделиться
Yes, a simple JST plug (probably type ACH)
Thanks for posting these instructions! I'm having trouble finding a battery that matches the one in the picture (unless I want to buy 1000 of them from Alibaba). Would this work?
http://www.ebay.com/itm/3-7V-1800mAh-Rec...
Dimensions are:
thick:3mm
wide:60mm
length:70mm
Clarke Robinson - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 16
За последние 7 дней: 110
За последние 30 дней: 444
За всё время: 48,741
