Введение
This guide will teach you how to properly replace the batteries in your Claw Machine. If you are experiencing any power related issues with your device follows these steps.
Выберете то, что вам нужно
Locate the battery compartment door on the bottom cover of The Claw.
Loosen the screw from the battery compartment door with your phillips head screwdriver.
Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
Еще один человек закончил это руководство.
1 Комментарий к руководству
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
