ThinkPad Edge E31 Hard Drive Replacement
Выберете то, что вам нужно
  1. ThinkPad Edge E31 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    Спросите у FixBot
    Добавить комментарий
  2. ThinkPad Edge E31 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    Спросите у FixBot
  3. ThinkPad Edge E31 Hard Drive Replacement, ThinkPad Edge E31 Underside Disassembly: шаг 3, изображение 1 из 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    Спросите у FixBot
  4. ThinkPad Edge E31 Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Remember to ground yourself before handing internal components of a laptop.
    • The hard drive is on the bottom left side of the exposed laptop.
    • Remove the 3.5mm long M3 screw securing the hard drive to the laptop.
    Спросите у FixBot
  5. ThinkPad Edge E31 Hard Drive Replacement: шаг 5, изображение 1 из 2 ThinkPad Edge E31 Hard Drive Replacement: шаг 5, изображение 2 из 2
    • On the left edge of the hard drive there is a plastic tab. Pull up slightly on this tab.
    • Pull the tab to the left to remove the hard drive from the laptop.
    Спросите у FixBot
  6. ThinkPad Edge E31 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • To remove the hard drive mounting bracket, locate the screws holding it on. There is one, 4mm long M2 screw on each of each on the long edges of the drive, and remove them. This will free the drive from the bracket. The bracket is needed to put the new drive back into the computer.
    Спросите у FixBot
Заключение
Riley
Участник с: 03/19/17
601 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 Участник UMass Dartmouth, Team S6-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G5
4 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 617
