ThinkPad Edge E31 RAM Replacement
Выберете то, что вам нужно
  1. ThinkPad Edge E31 RAM  Replacement, Battery: шаг 1, изображение 1 из 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    Спросите у FixBot
    Добавить комментарий
  2. ThinkPad Edge E31 RAM  Replacement: шаг 2, изображение 1 из 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    Спросите у FixBot
  3. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: шаг 3, изображение 1 из 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    Спросите у FixBot
  4. ThinkPad Edge E31 RAM  Replacement, RAM: шаг 4, изображение 1 из 1
    • The RAM slots are next to the hard drive to the right of the exposed laptop.
    • There are 2 flexible brackets holding each RAM chip in place is.
    • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
    Спросите у FixBot
  5. ThinkPad Edge E31 RAM  Replacement: шаг 5, изображение 1 из 1
    • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
    Спросите у FixBot
  6. ThinkPad Edge E31 RAM  Replacement: шаг 6, изображение 1 из 1
    • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
    • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
    Спросите у FixBot
Заключение
Riley
Участник с: 03/19/17
601 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 Участник UMass Dartmouth, Team S6-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G5
4 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 26
За всё время: 578
