Введение
This guide shows you how to replace the outer casing of the watch. If you have an outer cracked screen, main button, or case, then this is the guide you need.
Выберете то, что вам нужно
First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
Continue to lift up on the band until the screen of the watch becomes loose from the band.
Continue to pull up on the wristband until it is completely off the watch.
Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
Инструмент, используемый на этом этапе:Tweezers$4.99
Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
Use your fingers to gently pull the whole green motherboard out of the Front Casing.
You are finished when all parts have been removed to leave just the front casing by itself. To reassemble your device, follow these instructions in reverse order.
2 человек успешно провели ремонт по этому руководству.
9 Комментарии к руководству
Great explaination, though you mention you don't replacement parts...? Can you share a link where you found the new front cover assembly?
Same question as Dyeffen : where can we get some replacement screens ?
Ansre
a_limal@yahoo.com.au
Steffen sorry :-(
Same question: where can we find the replacement cover part?
Hello if the control button is tight can the button be removed and cleaned underneath
Imran
