Toshiba Chromebook 2 Display Replacement
Выберете то, что вам нужно
  1. Toshiba Chromebook 2 Display  Replacement, Display: шаг 1, изображение 1 из 1
    • If there is a crack on the outer case of the display so that the display is working properly, but there is distractions on the screen from the shattered case. In that case, the outer case can be easily replaced. It is just a matter of pulling the plastic case that’s stuck against the LED screen, and push the new case back in its place.
    Спросите у FixBot
    Добавить комментарий
  2. Toshiba Chromebook 2 Display  Replacement: шаг 2, изображение 1 из 1
    • • Shattered LED screen is when you push your finger against the screen, you see some kind of a rainbow effect around your finger. If the LED screen is shattered, it is unusable, and needs to be replaced with a new LED screen.
    Спросите у FixBot
  3. Toshiba Chromebook 2 Display  Replacement: шаг 3, изображение 1 из 1
    • If the light coming out of the display is not bright enough, check the picture settings manually, and try to adjust sharpness, contrast, and brightness.
    Спросите у FixBot
  4. Toshiba Chromebook 2 Display  Replacement: шаг 4, изображение 1 из 1
    • • If setting the picture manually did not change the brightness, it simply means that the LED in the back of the LED screen have broke. That means a new LED screen is required.
    Спросите у FixBot
  5. Toshiba Chromebook 2 Display  Replacement: шаг 5, изображение 1 из 1
    • To replace your display screen you need to shut down the computer first.
    Спросите у FixBot
  6. Toshiba Chromebook 2 Display  Replacement: шаг 6, изображение 1 из 1
    • In order to get to the screen assembly, you need to remove the screen bezel (plastic frame around the screen)
    Спросите у FixBot
  7. Toshiba Chromebook 2 Display  Replacement: шаг 7, изображение 1 из 1
    • To remove the bezel, you need to unscrew two screws in the bottom of the front screen hiding behind screw covers.
    Спросите у FixBot
  8. Toshiba Chromebook 2 Display  Replacement: шаг 8, изображение 1 из 1
    • Frist, remove the screw covers with a small hobby knife. Use a PH #0 (Philips screwdriver) to unscrew the couple of screws in the front screen bezel.
    Спросите у FixBot
  9. Toshiba Chromebook 2 Display  Replacement: шаг 9, изображение 1 из 1
    • Once you are done with unscrewing, snap off the screen bezel. To do that, you need to reach your fingernails of both hands on the inside of the screen bezel in the left or right side of the screen, and gently lift up and out.
    Спросите у FixBot
  10. Toshiba Chromebook 2 Display  Replacement: шаг 10, изображение 1 из 1
    • You will hear a snapping sound. Work your way around the screen bezel.
    Спросите у FixBot
  11. Toshiba Chromebook 2 Display  Replacement: шаг 11, изображение 1 из 2 Toshiba Chromebook 2 Display  Replacement: шаг 11, изображение 2 из 2
    • Once you take out the screen bezel, four screws mount the LED screen. Unscrew them, tilt the screen forward, and lay it on the keyboard exposing the backside of the screen.
    Спросите у FixBot
  12. Toshiba Chromebook 2 Display  Replacement: шаг 12, изображение 1 из 1
    • Once you do that, you will see the screen has only one connector. Use the hobby knife to lift up the adhesive tape (Be careful not to cut it) Pull the adhesive tape back, and grab the back of the connector with both your fingers, and gently pull the connector back out. Now the screen is loose.
    Спросите у FixBot
  13. Toshiba Chromebook 2 Display  Replacement: шаг 13, изображение 1 из 1
    • Put the new 13.3’ LED screen in its place and start by connecting the screen connector. Put the screen where it is supposed to be mounted at, and screw back the four screws that hold the screen.
    Спросите у FixBot
  14. Toshiba Chromebook 2 Display  Replacement: шаг 14, изображение 1 из 1
    • Now it’s a matter of putting the screen bezel back by pushing it in to stay around the screen.
    Спросите у FixBot
  15. Toshiba Chromebook 2 Display  Replacement: шаг 15, изображение 1 из 1
    • Finally, screw back the two screws on the bottom of the screen bezel, and cover them with the screws covers.
    Спросите у FixBot
Заключение
17 человек успешно провели ремонт по этому руководству.
Marwan Aljohani
Участник с: 10/01/15
599 Репутация
1 руководство автора
Команда
IUPUI, Team 1-3, Hagerty Fall 2015 Участник IUPUI, Team 1-3, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G3
5 членов
Автор 7 руководств
3 Комментарии к руководству
I completed this step by step and even though I knew it was to no avail. Upon my completion, it booted right up! Thank You Ifixit!!!!
Mechelle Leavitt - Ответить Поделиться
Thank you so much for the great description. I thought my Chromebook was dead in the water but the troubleshooting guide and instructions for the lcd screen was just what I needed. Even before I could get the bezel off completely the screen came alive. From now on I will call my CB “Lazarus” since it has “risen” from the dead.
Brian Todd - Ответить Поделиться
&&^& you so much it,s so bad
Yuel Berhane 7e Kyrkskolan 7-9 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 64
За всё время: 45,064
