Введение
This guide will show you how to replace your Thrive's battery.
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Remove back cover by prying away from the Thrive.
The easiest place to pry from is one of the two speakers.
To remove the battery, make sure the lock switch is in the unlocked position.
The battery is unlocked when the switch is slid to the unlocked position.
Slide the battery switch release to the right.
While holding the switch in place, lift up the battery.
7 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
You should give links on where we can buy the parts that need to be replaced.
