Введение
In this guide, you will learn how to replace the LED lights that are located on either side of the Treblab HD77. These LED lights indicate the current status of connectivity for the speaker and as a result are very helpful in using the speaker effectively. This guide aims to teach you how to replace these lights in the event that they stop working.
Note that this speaker is water resistant and as a result uses a water resistant adhesive in some areas which will have to be removed in certain areas in order to access the LEDs. To restore its water resistance, this adhesive will need to be manually reapplied before reassembling the speaker.
Make sure the device is powered off before disassembly.
Выберете то, что вам нужно
Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
There are four points where adhesive is used to hold the LED light strip down.
Lift up the LED light strip from the plastic casing.
Flip the LED light strip upside down to see where the cord is plugged in.
Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
