Trio AXS 3G Motherboard Replacement
Выберете то, что вам нужно
    1. Trio AXS 3G Motherboard Replacement, Back Case: шаг 1, изображение 1 из 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Спросите у FixBot
      Добавить комментарий
    2. Trio AXS 3G Motherboard Replacement: шаг 2, изображение 1 из 2 Trio AXS 3G Motherboard Replacement: шаг 2, изображение 2 из 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Спросите у FixBot
    3. Trio AXS 3G Motherboard Replacement: шаг 3, изображение 1 из 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Спросите у FixBot
    1. Trio AXS 3G Motherboard Replacement, Motherboard: шаг 4, изображение 1 из 1
      • The motherboard is a series of green panels. The larger portion is located above the battery and supports the camera. The smaller portion is located towards the bottom and supports the speakers. There are several connections that will need to be detached using a soldering tool.
      Спросите у FixBot
    2. Trio AXS 3G Motherboard Replacement: шаг 5, изображение 1 из 1
      • Using a #000 screwdriver, unscrew the 5 screws connecting the motherboard to the device.
      Спросите у FixBot
    3. Trio AXS 3G Motherboard Replacement: шаг 6, изображение 1 из 1
      • The battery will need to be disconnected from the motherboard.
      • Using a soldering tool, melt the two metal parts connecting the battery wires to the motherboard.
      • You have the option of removing the battery completely at this point. It will make the next step easier, but it is not required.
      Спросите у FixBot
    4. Trio AXS 3G Motherboard Replacement: шаг 7, изображение 1 из 1
      • Disconnect the silver tape that attaches the motherboard to the metal panel.
      Спросите у FixBot
    5. Trio AXS 3G Motherboard Replacement: шаг 8, изображение 1 из 2 Trio AXS 3G Motherboard Replacement: шаг 8, изображение 2 из 2
      • Disconnect the ribbon from the bottom portion of the motherboard.
      Спросите у FixBot
    6. Trio AXS 3G Motherboard Replacement: шаг 9, изображение 1 из 1
      • Remove the motherboard and set aside.
      Спросите у FixBot
    7. Trio AXS 3G Motherboard Replacement: шаг 10, изображение 1 из 1
      • The smaller portion of the motherboard is located at the bottom with the speaker.
      • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
      Спросите у FixBot
    8. Trio AXS 3G Motherboard Replacement: шаг 11, изображение 1 из 3 Trio AXS 3G Motherboard Replacement: шаг 11, изображение 2 из 3 Trio AXS 3G Motherboard Replacement: шаг 11, изображение 3 из 3
      • Located toward the bottom, carefully remove the yellow film.
      Спросите у FixBot
    9. Trio AXS 3G Motherboard Replacement: шаг 12, изображение 1 из 1
      • Gently disconnect the small ribbon found underneath the film.
      Спросите у FixBot
    10. Trio AXS 3G Motherboard Replacement: шаг 13, изображение 1 из 1
      • There is another connection found underneath this portion of the motherboard.
      • Lifting up the motherboard, disconnect the second ribbon found underneath.
      Спросите у FixBot
    11. Trio AXS 3G Motherboard Replacement: шаг 14, изображение 1 из 2 Trio AXS 3G Motherboard Replacement: шаг 14, изображение 2 из 2
      • Using a soldering tool, melt the six metal connections located towards the bottom of the tablet.
      • Do not melt the wires.
      • Once the connections are melted, the rest of the motherboard can be removed from the tablet.
      Спросите у FixBot
Заключение
Michaela Causey
Участник с: 09/20/17
328 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S7-G6, Thomas Fall 2017 Участник University of North Texas, Team S7-G6, Thomas Fall 2017
UNT-THOMAS-F17S7G6
3 членов
Автор 12 руководств
1 Комментарий к руководству
My grandma owns the 4G model and someone broke the volume down button. because of this the volume goes down on its own or the device goes into recovery mode. It actually reset it self by doing this but there is no use in me setting it back up just for it to be reset again. Any help you be great.
Dudefoxlive - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 33
За всё время: 873
