Trio STEALTH-9 Motherboard Replacement
Выберете то, что вам нужно
    1. Trio STEALTH-9 Motherboard Replacement, Back Cover: шаг 1, изображение 1 из 1
      • Remove the two Phillips #00 screws on the side of the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. Trio STEALTH-9 Motherboard Replacement: шаг 2, изображение 1 из 1
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      Спросите у FixBot
    3. Trio STEALTH-9 Motherboard Replacement: шаг 3, изображение 1 из 1
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      Спросите у FixBot
    4. Trio STEALTH-9 Motherboard Replacement: шаг 4, изображение 1 из 1
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      Спросите у FixBot
    1. Trio STEALTH-9 Motherboard Replacement, Battery: шаг 5, изображение 1 из 1
      • With the cover removed, slowly pull the electrical tape away as shown.
      Спросите у FixBot
    2. Trio STEALTH-9 Motherboard Replacement: шаг 6, изображение 1 из 1
      • Slowly pull the Battery away from the tablet frame.
      Спросите у FixBot
    3. Trio STEALTH-9 Motherboard Replacement: шаг 7, изображение 1 из 1
      • Prepare your Soldering Iron and Removal Tools.
      • Contact the iron with each of the battery leads, and pull the lead away from the board.
      • Remove any excess solder as needed.
      Спросите у FixBot
    4. Trio STEALTH-9 Motherboard Replacement: шаг 8, изображение 1 из 1
      • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
      • Apply heat and solder to each lead individually.
      • Remove any excess solder if flooding occurs.
      Спросите у FixBot
    1. Trio STEALTH-9 Motherboard Replacement, Camera: шаг 9, изображение 1 из 2 Trio STEALTH-9 Motherboard Replacement, Camera: шаг 9, изображение 2 из 2
      • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
      Спросите у FixBot
    2. Trio STEALTH-9 Motherboard Replacement: шаг 10, изображение 1 из 2 Trio STEALTH-9 Motherboard Replacement: шаг 10, изображение 2 из 2
      • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
      Спросите у FixBot
    3. Trio STEALTH-9 Motherboard Replacement: шаг 11, изображение 1 из 2 Trio STEALTH-9 Motherboard Replacement: шаг 11, изображение 2 из 2
      • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
      • Remove the camera from the frame and replace as needed.
      Спросите у FixBot
    1. Trio STEALTH-9 Motherboard Replacement, Speaker: шаг 12, изображение 1 из 1
      • Slowly remove the electrical tape holding down the Speaker wires.
      Спросите у FixBot
    2. Trio STEALTH-9 Motherboard Replacement: шаг 13, изображение 1 из 2 Trio STEALTH-9 Motherboard Replacement: шаг 13, изображение 2 из 2
      • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
      Спросите у FixBot
    3. Trio STEALTH-9 Motherboard Replacement: шаг 14, изображение 1 из 1
      • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
      • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
      Спросите у FixBot
    1. Trio STEALTH-9 Motherboard Replacement, Motherboard: шаг 15, изображение 1 из 1
      • Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
      Спросите у FixBot
    2. Trio STEALTH-9 Motherboard Replacement: шаг 16, изображение 1 из 3 Trio STEALTH-9 Motherboard Replacement: шаг 16, изображение 2 из 3 Trio STEALTH-9 Motherboard Replacement: шаг 16, изображение 3 из 3
      • Remove the three #00 Screws holding down the Motherboard.
      Спросите у FixBot
    3. Trio STEALTH-9 Motherboard Replacement: шаг 17, изображение 1 из 2 Trio STEALTH-9 Motherboard Replacement: шаг 17, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Use a pair of Tweezers to carefully pull the side buttons away from the frame.
      • Use the same Tweezers to carefully pull the microphone away from the front of the frame.
      Спросите у FixBot
    4. Trio STEALTH-9 Motherboard Replacement: шаг 18, изображение 1 из 3 Trio STEALTH-9 Motherboard Replacement: шаг 18, изображение 2 из 3 Trio STEALTH-9 Motherboard Replacement: шаг 18, изображение 3 из 3
      • Use your fingernails or a plastic opening tool to remove any remaining ribbon cables from the Motherboard.
      Спросите у FixBot
    5. Trio STEALTH-9 Motherboard Replacement: шаг 19, изображение 1 из 1
      • With the cables removed, lift the Motherboard off of the frame.
      • Repair or replace the Motherboard as needed.
      Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
2 человек успешно провели ремонт по этому руководству.
Mei Liang
Участник с: 01/29/15
228 Репутация
Автор 2 руководств
Команда
Clemson, Team 15-5, Shirley Winter 2015 Участник Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 членов
Автор 4 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 26
За всё время: 999
