Trunk LED Tailgate Strip Light Installation
Выберете то, что вам нужно
  1. Trunk LED Tailgate Strip Light Installation, Cleaning: шаг 1, изображение 1 из 2 Trunk LED Tailgate Strip Light Installation, Cleaning: шаг 1, изображение 2 из 2
    • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
    • Use soap and water to scrub the area clean since that place is normally dirty.
    Спросите у FixBot
    Добавить комментарий
  2. Trunk LED Tailgate Strip Light Installation, Mounting time: шаг 2, изображение 1 из 2 Trunk LED Tailgate Strip Light Installation, Mounting time: шаг 2, изображение 2 из 2
    • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
    • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
    • Straighten the LED strip and peel adhesive.
    • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
    Спросите у FixBot
  3. Trunk LED Tailgate Strip Light Installation, Wire tapping: шаг 3, изображение 1 из 3 Trunk LED Tailgate Strip Light Installation, Wire tapping: шаг 3, изображение 2 из 3 Trunk LED Tailgate Strip Light Installation, Wire tapping: шаг 3, изображение 3 из 3
    • Tap reverse light wire.
    • You will need to remove either side of the tail light to locate the reverse light.
    • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
    Спросите у FixBot
  4. Trunk LED Tailgate Strip Light Installation, Find the connector: шаг 4, изображение 1 из 2 Trunk LED Tailgate Strip Light Installation, Find the connector: шаг 4, изображение 2 из 2
    • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
    • You will find the trailer light connector near the tow hitch.
    Спросите у FixBot
  5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: шаг 5, изображение 1 из 3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: шаг 5, изображение 2 из 3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: шаг 5, изображение 3 из 3
    • Hide the wires or zip-tie them.
    • Check the trunk LED tailgate lamp to make sure everything works.
    Спросите у FixBot
Заключение
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
5 человек успешно провели ремонт по этому руководству.
Eric Wu
Участник с: 01/21/15
3 600 Репутация
Автор 23 руководств
21 Комментарии к руководству
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - Ответить Поделиться
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 - Ответить Поделиться
Anyone have the answer to this problem yet?
Trevor G - Ответить Поделиться
I'm having the same problem!
Richie - Ответить Поделиться
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 16
За последние 30 дней: 94
За всё время: 44,523
