Введение
If your backpack/bag tuck lock clasp is broken, missing, or unable to lock your bag, use this guide to replace the tuck lock clasp.
Before using this guide, inspect there is any small buildup or dust at the tuck lock clasp, which may affect use; it can be removed using pointed tweezers or small brush. Be sure to test the tuck lock a few times to make sure it is not stuck.
Выберете то, что вам нужно
Place one hand holding on to the strap and another grabbing the clasp.
Pull the strap and clasp away from each other until completely separated.
Push the new clasp onto the strap.
Ensure that the screw holes of the strap and clasp are lined up with each other.
Ensure your replacement tuck lock clasp works by inserting the tuck lock clasp into the base plate.
