Tungsten T3 Screen Replacement
Выберете то, что вам нужно
  1. Tungsten T3 Screen Replacement, Screen: шаг 1, изображение 1 из 1
    • To remove the cover press down on the center indentation and remove from device.
    • Reminder: If you have a memory card inserted into your device make sure to remove it.
    Спросите у FixBot
    Добавить комментарий
  2. Tungsten T3 Screen Replacement: шаг 2, изображение 1 из 1
    • There will be a set of screws located on each side of your device. Remove these by using a Phillips head screwdriver.
    Спросите у FixBot
  3. Tungsten T3 Screen Replacement: шаг 3, изображение 1 из 1
    • The back panel must be removed in order to proceed. Slide the cover so that it is fully extended.
    • The arrows in the picture indicate two small holes located at the top of the device. Insert a paper clip or a tack simultaneously into each of these holes and moderately push downward.
    • The springs will give as pressure is exerted. Once you feel this take place, pull down the cover with the paper clip/tack while continuing to push downward. This will release the back cover.
    Спросите у FixBot
  4. Tungsten T3 Screen Replacement: шаг 4, изображение 1 из 1
    • Now the buttons and sliding tray will be connected to the main body only by an orange cable.
    • Gently peel this cable from the device.
    Спросите у FixBot
  5. Tungsten T3 Screen Replacement: шаг 5, изображение 1 из 1
    • Make sure that the cable remains connected to the buttons. Do not sever its connection to the sliding tray.
    • Disconnect the cable from the main body of the device by pulling upward.
    • Set aside the buttons and slide tray, making sure the orange cable is with it.
    Спросите у FixBot
  6. Tungsten T3 Screen Replacement: шаг 6, изображение 1 из 1
    • The arrows indicate two small screws. Using a Phillips head screwdriver, remove them.
    Спросите у FixBot
  7. Tungsten T3 Screen Replacement: шаг 7, изображение 1 из 1
    • To open the device, the sides must be (with moderate force) pried apart using a prying tool as seen in the picture.
    • Both sides must be separated from one another.
    • Tip: The right side may be slightly more difficult. It will be easiest to begin on the left.
    • Beginning with the left side, gently pry at the division of the face plates until they separate from one another.
    • Repeat this process on the other side of the device.
    Спросите у FixBot
  8. Tungsten T3 Screen Replacement: шаг 8, изображение 1 из 1
    • Hint: There will be pressure points along the side (as seen in the picture). Exerting pressure in these points will allow the sides to separate more easily.
    Спросите у FixBot
  9. Tungsten T3 Screen Replacement: шаг 9, изображение 1 из 1
    • Remove the face plate and set aside. This will leave the core of the device in front of you.
    • Reminder: The core of the device will be connected by various cables. Gently lift the screen and mother board (as in picture).
    • As labeled in the picture, the orange screen cable will connect on the lower right side of the motherboard.
    • Disconnect the cable by pulling it upward from the motherboard connection. Depending on your device, it may require little to moderate force.
    • Carefully remove your screen.
    Спросите у FixBot
  10. Tungsten T3 Screen Replacement: шаг 10, изображение 1 из 1
    • Next, the new screen must be connected to the motherboard.
    • Connect the new orange cable into the same location as the previous screen. (Location noted in picture by arrow). Make sure the cable is placed facing downward on the connection.
    • Lower the motherboard into place. Make sure to keep the back facing downward. Hint: This will be the side where all cables are connected.
    • Gently lay the screen on the core of the device.
    Спросите у FixBot
  11. Tungsten T3 Screen Replacement: шаг 11, изображение 1 из 2 Tungsten T3 Screen Replacement: шаг 11, изображение 2 из 2
    • As seen in figure one, the core and screen are now in tact.
    • Lay the face plate on device. It must be snapped into place.
    Спросите у FixBot
  12. Tungsten T3 Screen Replacement: шаг 12, изображение 1 из 1
    • Hint: when attaching the tray to the main device, the cable must be in the position as seen in the left figure.
    • Hint: On each side, the prongs must be adjusted so that they fit into their respective slots.
    Спросите у FixBot
  13. Tungsten T3 Screen Replacement: шаг 13, изображение 1 из 1
    • To reconnect the sliding tray and buttons, lay the device on its face.
    • Reminder: The orange button cable must be raised above sliding tray and connected to its respective port (as seen in picture).
    Спросите у FixBot
  14. Tungsten T3 Screen Replacement: шаг 14, изображение 1 из 1
    • To reconnect the sliding track, align the hooks and tracks (noted in picture).
    • Push the hooks into the tracks and slide the tray upward. This should lock the hooks in place.
    • To ensure that it has been connected properly, slide up and down.
    Спросите у FixBot
  15. Tungsten T3 Screen Replacement: шаг 15, изображение 1 из 1
    • Install the screws on both sides of device as seen in the picture.
    Спросите у FixBot
  16. Tungsten T3 Screen Replacement: шаг 16, изображение 1 из 1
    • Here is your repaired Tungsten T3 Palm Pilot. Enjoy!
    Спросите у FixBot
Заключение
Whitney
Участник с: 09/08/11
318 Репутация
Автор 3 руководств
Команда
University of Maine, Team 1-14, Diaz Fall 2011 Участник University of Maine, Team 1-14, Diaz Fall 2011
UMAINE-DIAZ-F11S1G14
2 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 16
За всё время: 1,838
