Введение
The talkback cable connects to your device in order to produce sound through your headset. The talkback cable may wear out after extensive use or damage. This guide will take you through the steps necessary to replace your gaming headset's talkback cable.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
Cut the talkback cable below where it enters the speaker housing.
Remove the cut section of the talkback cable.
Lift the motherboard up and out of the housing.
Take care not to strain the wires.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Thanks for the run down but could you please share what cable you used to replaced old one with? is it just 3.5mm jack, four pole extension cable which you stripped on one side ?
