Ukulele String Replacement
Выберете то, что вам нужно
  1. Ukulele String Replacement, Ukulele String Replacement: шаг 1, изображение 1 из 1
    • Prepare by gathering all of the things you'll need: your ukulele, the new string, a pair or scissors, a sharpened pencil, a cloth, a string winder (optional), and a tuner or tuning app. Make sure you purchase the right sized strings.
    • Remove the old string by untying it from the bridge.
    • Unwind the string with its tuning peg.
    Спросите у FixBot
    Добавить комментарий
  2. Ukulele String Replacement: шаг 2, изображение 1 из 1
    • Clean the ukulele with a paper towel or cloth. Make sure to clean around the bridge and the tuners.
    Спросите у FixBot
  3. Ukulele String Replacement: шаг 3, изображение 1 из 1
    • The next step is to smooth run the strings. Use a sharpened pencil to add a little graphite to the indent where the string will lie. This helps the string slide smoothly through the slot.
    Спросите у FixBot
  4. Ukulele String Replacement: шаг 4, изображение 1 из 3 Ukulele String Replacement: шаг 4, изображение 2 из 3 Ukulele String Replacement: шаг 4, изображение 3 из 3
    • Tie-up the string to the bride of the Ukulele. Begin by sliding one end of the string through the holes on the bridge. Then wrap it around itself, as shown in the image. Make sure that it is snug against the bridge.
    • With the excess string, wrap it under the string once, and then twice. This will prevent the string from slipping.
    • Finally, to make it anchored, pull the string tightly into place.
    Спросите у FixBot
  5. Ukulele String Replacement: шаг 5, изображение 1 из 3 Ukulele String Replacement: шаг 5, изображение 2 из 3 Ukulele String Replacement: шаг 5, изображение 3 из 3
    • Put the end of the string through the hole in the tuning peg, and tightly wrap the string around the peg three times.
    • If it is wrapped more than three times, it may interfere with tuning, and less than three times could make it less secure.
    • Next, turn the tuning peg until there is tension in the string. This process can be sped up by using a string winder. Then snip off the excess string with a scissors.
    Спросите у FixBot
  6. Ukulele String Replacement: шаг 6, изображение 1 из 1
    • The final step is to tune your ukulele. Although this can be done by ear, you may find it easier to use a tuner or a tuning app.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Bekah Klemp
Участник с: 09/19/18
154 Репутация
1 руководство автора
Команда
University of Minnesota, Team S1-G6, Card Fall 2018 Участник University of Minnesota, Team S1-G6, Card Fall 2018
UMN-CARD-F18S1G6
3 членов
Автор 1 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 33
За всё время: 1,651
