Введение
This guide describes the necessary steps to replace the logic board. This guide is used to replace smaller components within the logic board, such as the micro USB and auxiliary ports. When following this guide, you will need a plastic opening tool and a Phillips PH0 screwdriver.
Выберете то, что вам нужно
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Инструмент, используемый на этом этапе:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
Undo the connector of the flat white ribbon between the switches and the logic board.
