Введение
This guide will show how to replace the camera in the Vtech InnoTab Max.
Выберете то, что вам нужно
Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
Here you can see the back cover has been fully removed and you can now access the front cover.
To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
Еще один человек закончил это руководство.
